The name of the trailer is not really a good indicator of it's weight.. Neither is it's brochure 'dry weights'...
Look at the sticker for the rigs GVWR. Sure, you don't load anything in your rig, so you'll never get to that weight, but look at it anyway, because eventually, you'll get there... ha, ha... :)
I have a #7000 GVWR TT that is called a "Mini-Lite".. It's loaded for bear and I carry full load of fresh water too!
Tow it with an F150.. OMG.. :)
Plus I load the bed with all kinds of stuff too..
Tows fine and made a few mods to help, but in the end, it's a great tow and has some 108,000 miles on it now..
In the end, get the rig that works best for you and if it works, "you chose wisely".. If not... Well, then "you chose poorly".. :)
Good luck! Mitch
