kmfvfr wrote:
NC Hauler wrote:
atlgagent57 wrote:
We recently purchased a 2011 Toyota Tundra CrewMax Platinum Edition with the 5.7 Engine, Towing Package, 20 inch wheels and it has the 5.6 Bed. The Tundra is rated to tow 10,000 lb. I'm having the tires replaced with E Rated (10 ply) tires and I'm having rear Timbrens installed over the leaf springs It has also been fitted with an automatic slide 5th wheel hitch for pulling a 5th wheel. We also purchased a 2008 Keystone Laredo 5th Wheel with a 7740 Dry Weight and a 1440 Hitch Weight according to the manufacturers labels. It's a 30 footer with one slide. There are just the two of us and two lap dogs so we won't be loading the camper to the max. Bikes go on the rear of the 5th wheel which should help the pin weight. I've pulled it a couple of times on the Interstate and it pulls fine. A lot of it is using common sense when towing regarding speed and allowing plenty of space to stop. Exceeding the speed limits and riding the guy in front's rear bumper is simply inviting trouble no matter what your towing vehicle is. I've also seen plenty of 3/4's and 1 Tons out there towing a TT that is not set up correctly that are far more dangerous than my half ton rig. I've matched the two up the best I can, added some safety features and will use common sense when we're out there.
As I noted earlier, the OP has asked for no input in any way shape or form. He has the TV and the 5er and is telling us why it will work, whether we believe it will or not. He's doing some things no one else has ever though of before :).
I would like to know what the "added safety features" are and how much common sense was actually used if, as the OP stated, he is no more than 1,000# OVER his trucks GVWR.
The "added safety features" would be the E rated tires and Timbrens. I would say it is still far overloaded. A buddy recently bought a 35' toyhauler to tow with his F250. The pin weight of that rig was 3,500 lbs dry, and his cargo capacity on the F250 was 2,100 lbs. Needless to say it is now being towed with an F350 dually.
The "E" rated tires work, but all timbrens do is keep the truck bed from "bottoming out".
I love how some use "dry weights", (also dry pin weights), to sometimes justify what they're going to tow, as though the dry weight is going to be what they're going to tow. Most know you could easily load 1,000# for a family camping.......wouldn't really know till unit is loaded.
I too would like a report on how it tows...better yet, long term on how suspension, tranny and drive train hold up over a year or so of towing....Take that combo to the bottom of I26 where you tow from TN into NC and I'd bet by the time he got to the top of the mountain, he'd be ready to get another truck, or go with a lighter weight 5er...and that's just one itty bitty example...
states he lives in the "south-east"...maybe he only tows flat land, no hills or mountains...
