Dawne1290
Aug 02, 2021Explorer
Hand crank help
Hello! We just bought a 2007 Fleetwood saratoga highlander pop up trailer it. Has a power lift on it. But the hand crank post seems worn down when we attach the hand crank it doesn’t catch in the post so it won’t do anything. But I would like to have it for back up just in case the motor ever goes! The post that the hand crank slides on to has a little nub that comes up through the post that I am assuming should go through the slots on the hand crank so that it catches and actually turns the gears amd isn’t just spinning on the post. But it’s so worn down that the hand crank just spins. If that makes any sense. I can’t figure out how to post a picture I do have some though! What’s the best way to fix it?
