dadmomh
Jan 22, 2015Explorer
If you're thinking lightweight such as some small pictures, etc, sticky Velcro is perfect. If you need to remove it, it's easy and if there is any residue remaining, some Goo Gone will fix that. In both trailers, DH has used screws for the items you mentioned, but used small plastic anchors as well. He tried just using screws on a small spice rack and it is wasn't a huge success. The anchors fixed it up. If you plan on putting anything on a surface that has the wood finish, be advised that the finish is not always real wood, but a plastic-y finish and the Velcro will pull that little bit off, so try to just use the walls if you can.
