The older style electric motor covers have a small hole on the bottom. With an air nozzle you give a couple shots of compressed air into the hole and the cover slides down like a piston and comes off very easily.
When the cover is off you will see very small weep holes in the bottom of each motor housing. That is where you spray 3 in one oil using the spray straw, you press it as close and as well as you can on the weep hole until you see oil saturating the lower housing and weeping out the other side.
It's this lower bearing inside the bottom that invariably collects moisture (you can see a low point to the housing) where the bearing is and is important to sometimes blow with air if you suspect moisture has built up in there from neglect.
I do this every year and/or after camping trips in rainstorms. It has really helped to keep my jacks running smoothly.
It also helps to wipe on oil all over the motor housing to prevent corrosion too.
After oiling slide the motor covers back up in place being careful not to cover the hole with your hand so air can escape while pushing up. Always hold the gear head when pushing the covers back on so you don't stress the plastic gear cover on top.
After removing the white 'cup' covers each year I found the covers would begin to slide down on their own in extreme summer heat. So I applied ss clamps near the top of each 'cup' cover hiding the screw to the back.
I make winter covers during storage by using scissors to make cuts in ziplock freezer bags sliding them over the top and covering the gear head and electric motors.
I fasten the plastic ziplock bags against wind storms by stuffing packaging foam wherever it fits tight to hold the plastic cover I made.
