tiptoptune
Nov 06, 2021Explorer
Jack leg help - Happi jac
left rear leg on my 2000 Bigfoot TC with happi jacs will not go down. It does work if i switch the wires at the logic board controller to another location. So the wiring to the leg is good. Spiral cord ohms out. so has to be the hand push button control or the main logic board controller.
Any ideas how to tell which is bad?
Any electric geeks out there want to compare my test to theirs? measured volts at cord connector on the logic board controller with cord disconnected and connector facing me, starting from the left, first 4 pins had 0.9 volts, 5th pin has 5 volts, 6 & 7 have 0 volts, 8th pin has 5 volts. Have the same readings at the cord that plugs into the hand control. I used a back probe thin wire end on my test leads to touch one pin at a time.
Thanks for any help.
