Kidoo
Jan 17, 2014Explorer
Happijac - Unhappy
Hi, anybody took their Happijac electric motor apart when seized? Or oiled them? Can we take the cap off to lubricate inside? Apparantly the oil seal that is on the output shaft is not making it's job to keep moisture out.
I got two of my electric motor on the Happijac seized. I took it to an electric shop and he took one appart to clean it. There was some rust on the brushes, motor works fine now.
He had to make a cut along the housing to take it appart, do not know if it will last. He just hitted the other one and it worked.
I saw a thread on another forum stating that you can prevent rust or water to sit inside the motor. He was talking about the Weep hole under the motor and spraying some oil on the top. I found the weep hole at the bottom but do not see how I can spray oil from the top?
