nick_m wrote:
...Can you clarify what you meant about "try loosening the 6 bolts... to see if it would move"? No matter where I moved the jack prior to tightening the bolts, the round hole square peg arrangement always forced it back to the same orientation.
The 3 bolts at either side of extension, between ext and jack and the 3 between ext and camper mount flange. IF there is any clearance of thru holes and bolt diameter, might gain a bit. By your description though sounds like maybe pretty snug. I dont know how tight the tolerances are. Going to take a small file to open hole horizontally without enlarging to much. Dremel would work but only 2 holes.
When jacks were bolted direct to camper flange was this 1 1/2" noticed?
