bigfootford
Jul 26, 2013Nomad III
Sheriffdoug wrote:
Jim,
I built a support out of 5 to 6, 3ft lengths of 6"x4", under the basement, lowering corner with jacks,
evenly on to support column built, to sit firm on the three remaining jacks and support, then manually
wind up small amount of jack to be fixed, and un bolt & repair.
Purchase timber from lumber shop/salvage yard as required. Store 2-4 in Truck bed at sides, with TC for emergency use. Can be used, so as to not over extend camper jacks, base plates for changing tires for truck jack, chocks for wheels, or bed stops at rear of
Truck bed to prevent damage.
After fixing Jack, re-install, raise leg to tension, raise all legs slightly, then remove wooden supports.
Good Luck, Doug
That's a good way to do it...
I just leave the camper on the truck. remove the jack that I want to do maint on....Do the maintenance and put the jack back on... 1 hr max and I am done with 1 jack.
Jimj
