Diggerwalker wrote:
I've now had my second Happijac4150 collapse on me.No warning, just bang!Fortunately it fell onto my partially withdrawn vehicle both times otherwise the camper, would have fallen onto its side.The additional problem,on both occasions, it twists & bends the leg that takes all the load so you end up replacing two! The  failed jacks were 1998 vintage ( my latest episode twisted a brand new jack, replaced after the first episode)  Can anyone say if the 'failsafe' feature spoken about, is a fairly recent addition? I would say in conclusion, that if anyone else has experienced similar problems, do check the leg that took the 'twist' as I nearly missed the problem. Alive to this problem with the latest collapse, I was quick to spot the bent leg which also included a twisted Zed mounting bracket.
I'm a U.K member and demountable campers  with Happijacks are as 'rare as hen's teeth' here, so any help or comment would be helpful.
Collapse?  This would not be a fault of the described roll pin problem.
Are  the 4150's on the front of your camper?
Are you saying that the bracket/jack mount that attaches to the camper gave way or what?
There has been no instance reported on this TC forum of a 4150 or 4500 collapsing.
Any jack that is grinding/groaning/clicking should be serviced immediately...
As an additional note.  There was a post that someone did that said they were able to remove a slight bend in one jack leg that was bent when someone bumped their camper and it toppled.
Jim
