Reddog1
Jul 26, 2016Explorer II
lakeside013104 wrote:My personal opinion says it makes no difference, but I do suggest to follow the manufactures recommendation. I really do not recall, but I think the manufacture recommends the spring tie downs in the front. Do verify if this is true.
Question:
Is it recommended to have the spring loaded turnbuckles on the rear tie down connection points of a TC or are spring loaded turnbuckles used only on the front?
Thanks.
Lakeside
I should point out, you can tighten them to the point the spring is totally compressed or the rubber bumper is totally compressed. This raises the question, how do you know when you have 300 lbs pressure? I think the answer is to follow the manufactures instructions, and think carefully as to what is the purpose of tie downs.
Wayne
