MORSNOW
Dec 29, 2015Navigator III
getpower1 wrote:
As far as the Happijac tie down system goes...I know what I did to install it. There are a lot of people that have been using it for years and with heavier campers. I drilled the holes into the brackets that are welded to the frame and bolted them in myself. It's a lot more sturdy that the plywood that the eye bolts in the camper are mounted to. I'm more than happy with the way the system is engineered to work.
Most folks who have never used or installed Happijac tie downs don't know or pay attention to the bracket that is bolted to the frame and up to the front mount and "assume" you are only bolted to the front box. You will be fine, 1,000's of others have ran these for years, including extreme off-roading with a loaded camper.
44,066 PostsLatest Activity: Mar 14, 2015
