I have an AF 1150 and one by one my jacks stopped working over the last year. I use a Makita battery drill and it will raise and lower the jack legs on the truck but when it hits the full weight as it leaves the springs of the truck it does not have enough juice to raise it. I use a 1/2" ratchet with a 1/2" hex socket to continue the raising or lowering while I flip the lever for manual on the jack.......I have 2 questions.
1) How long will the plastic socket last doing it this way?
2) Is there a battery operated drill that would lift the weight?
I do not want to use an impact drill because I think that would damage the fitting. This method takes about 30 minutes as I move around the TC.
Dave
