BradW wrote:
covered wagon wrote:
JimK-NY wrote:
Unfortunately the Happijac motors are junk. The issue is poor sealing against water intrusion. I have tried various methods for sealing the motors but still have had two fail.
I also remove the white plastic cups to the electric motor and squirt oil in the electric motor bearing. The bottom bearing gets the water build up, corrodes, slows down the motor, eventually seizing.
That is an obvious design issue. Has Happijac fixed this on the newer jacks? The have to know they have a designed in flaw.
Thanks,
BradW
If you are referring to the 4800's they use the same motor and one of mine (22 months old) has failed.
