JerBear's avatar
JerBear
HAPPIJAC Wireless Remote Problem
I am having an issue with my HappiJac wireless remote. The green light will not go off and if the main board has power to it all 4 jacks start to raise the camper. Only way to stop this is to pull the batteries in the remote or unplug the power from the main board. If the batteries are out of the remote overnight and I put them back in the morning the remote will turn on and off ok and the jacks work ok for maybe an hour. Then after an hour or so if I go to turn on the remote....same problem. Light will not go off and all 4 jacks lift untill I unplug the board or take the batteries out. Any ideas?
JerBear
  • Z-Peller wrote:
    Have you tried using the remote with supplied cord plugged directly
    into unit box inst
    ead of wireless? Would be interesting to see what it does.
    Just tried that...same problem!
  • Have you tried using the remote with supplied cord plugged directly
    into unit box instead of wireless? Would be interesting to see what it does.
  • Yeti plus wrote:
    Sounds like the remote may have moisture in it. Take out the batteries and put the remote in a Ziplock bag and add some rice. Let sit for acouple of days and see what happens.
    Try changing the batteries in the remote. Put new batteries in. We have had some odd things happen with television remotes and computer mice with batteries that tested good but worked fine with new batteries.
    Brian
    Have tried new batteries already. Will try the ziplock and rice trick. Worth a try. Pulled the batteties out if it yesterday when it would not turn off. Put them in this morning and for now it is working. But I am sure after an hour or so will not be able to turn off remote.
  • Try changing the batteries in the remote. Put new batteries in. We have had some odd things happen with television remotes and computer mice with batteries that tested good but worked fine with new batteries.
    Brian
    As said above....put new batteries in remote.
  • Sounds like the remote may have moisture in it. Take out the batteries and put the remote in a Ziplock bag and add some rice. Let sit for acouple of days and see what happens.
    Brian
  • guidry wrote:
    Is there a way to reset the system?
    The HappiJac website gives instructions on how to reset. No luck. But thanks!!
