terrybkExplorerAug 11, 2022Happijack Swing Out Bolt Removal?One of the bolts on my Happijack swing out arms is starting to stick. It's the bolt where you push up on the nut at the bottom so you can rotate it the jack. I need to get in there and clean it out. ...Show More
bigfootgreyExplorerAug 11, 2022I would suggest trying a penetrating oil like PB Blaster first and see if that un sticks it
Related ContentStaple RemovalHappijack BedEasy way to remove slide topper?Good happijack matttressTailgate Removal
