joerg68
May 20, 2021Nomad III
The center of gravity is roughly 1/3 of the way back on the camper floor on most campers. It will not topple.
But the jacks are not designed to take a lot of side (right/left/fwd/aft) loads. As far as I see it, you would create a forward momentum on the front jacks which would try to bend them backwards. They are under a lot of stress as is and don't have a lot of reserves. A jack mount might fail or a jack leg might bend, or a jack might loose footing and slide away. In which case you will end up with a buckled jack and a camper on the front or side...
(Sorry for potentially botched non-engineering language. Not an engineer, and not a native english speaker at this end)
