jimh406
May 20, 2021Explorer III
There really isn’t any reason to when you are loading/unloading. Instead, I think the common recommendation is to raise the front slightly to be able to pull out without dragging. Off the bed, you probably would only need to barely have the front or rear out of level assuming you picked a reasonable spot.
