mkirsch
May 26, 2021Nomad II
StirCrazy wrote:HMS Beagle wrote:
Happijacks explanation must be out of an "abundance of caution". Suppose you had a camper with the CG 4 feet off the floor and 2 feet back from the front of the box. Most large campers would sell their soul to get the CG that far forward. To tip it to the balance point you'd have to get it 26 degrees nose down. With 4' of jack travel and a short box camper, you might just be able to manage that. Not sure why you would try, it's kinda like telling kids not to put beans in their nose.
I am not rich enough to have electric jacks so I am constantly lifting the back end higher than the front and vise versa when loading and unloading as I dont have enough arms to pump all 4 jacks at the same time. I have checked to see how stable it is and it is real stable at a slight inclanation so I am not concerned with how I do it, but it would be nice to be able to do all 4 at once and eliminate that whole procedure.
OBVIOUSLY we are not talking about, "If you raise the rear even a FRACTION OF AN INCH higher than the front, you will open a portal to hell and release Satan and all his demonic minions."
It has to be some significant amount. Why they don't specify, is because it's easier to say "Don't do it AT ALL!" and not leave it open to interpretation.
"Don't raise your camper more than 25 degrees," gives the end user ideas. Plus if the weight distribution of the camper is not "standard" that number will change. Let's say they loaded the cabover storage with bricks, and it tips over at 24 degrees.
