HMS_Beagle
May 27, 2021Explorer II
There is no mystery to the engineering of steel tube, round, square, or otherwise. Both shapes resist torsion and bending. And a square tube will resist both more bending, and more torsion (and more compression while we are at it) than a round tube of the same dimensions. This is very well worn and reliable science that can be found in any properties of materials textbook.
I think these myths stem from the fact that using a given amount of material, you can make a round tube that is slightly stronger than a square one. In other words, the same amount of material used to make a 2" square tube could have been used to make a 2.5" round tube, and the round tube will be stronger. But at the same dimensions - 2" tube to 2" tube - the square tube is stronger.
