danimal53 wrote:
i get your point soundguy, the coffee part was certainly more of an afterthought. it's probably easier/cheaper to just boil some water and get a french press!
so, my original plan, just a TV and sometimes to charge small electronics.
so if i went with a small inverter (300-400w max) closer to the battery, heavy wire (4 or 6) i think i'm in business.
You're getting closer for sure. The inverter needs to be close to the battery and have large ga wires and a fuse. Then you can extend the AC side to wherever you need the power with smaller wires (maybe 12-14ga).
