jmiller12's avatar
jmiller12
Harsh Lighting
Only my second post so take it easy on me. The lighting in our new 2018 Winnie 2455BHS is very harsh (like hospital lighting). First, how do I get to the bulb itself? I tried to jiggle the plastic lighting cover and it didn't pop off easily so I didn't want to rip it out of the ceiling. Second, does anyone have a bulb they prefer that has more of a soft indoor lighting glow to it, preferably that I can get off Amazon. Thanks.
  • Led bulbs come in a variety of color temperatures. They are usually expressed in degrees Kelvin. They are sometime categorized a blue white, bright, warm, natural, and other such terminology. The lower the color temp the more they look like incandescent bulbs.
    The reason for the bright light is because TT interiors tend to be dark. You will notice this if you try to read a book.
    You can try a 10 pack of bulbs from Amazon fairly cheap. Look under RV light bulbs.
    To open a ceiling light most of the time you squeeze the long sides of the clear cover and tilt it down. You need to see what kind of bulb they use.
    I have seen a few florescent bulbs in TTs, I am not sure of the color temperature choice with those.
    Finally you can delve deep into RV lighting on YouTube.
    Good luck
