djcjc
Jun 29, 2017Explorer
Hauling water
Whenever we go to the races in Joliet I travel with water tanks full only a 20 minute drive and buy water only if we run out. Headed to the race in Sparta KY about 6 hr drive no water hookup at CG bu...
Ralph Cramden wrote:Atlee wrote:
Then I would avoid a Forest River mini/ultra lite trailer.mordecai81 wrote:
Some TTs are not designed to carry a full tank on the road. Forest River says there mini/ultra lite lines should carry only 1/3 of a tank when towed. The braces holding the fresh tank to the frame are incredibly light. My front brace was bent at a 30 degree angle from carrying a full load-it would have eventually failed completely. My helpful neighbor welded some angle iron to the front and rear braces so it's solid now.
That's a no brainer. The thing is they only tell people that after a problem. As stated in my post above its not just the mini lights or ultra lites that have the failures, and its not just FR either. The issue go's back to Lippert and the under engineered junk they produce, but the way I see it the RV manufacturer chooses that junk so its on them.
