djcjc
Jun 29, 2017Explorer
Hauling water
Whenever we go to the races in Joliet I travel with water tanks full only a 20 minute drive and buy water only if we run out. Headed to the race in Sparta KY about 6 hr drive no water hookup at CG bu...
JBarca wrote:My TT came with 2- 42 gallon grey, 2-42 gallon Black, and 1 42 gallon fresh water tanks.
Your note mentioned travel with "full tanks". Tanks being more then one. No one here yet talked about full black or gray tanks. In our case there is no way I would travel with full black or gray tanks long distances at full highways speeds. My tanks black and gray are ABS and held to the bottom of the camper floor joists (not the frame) with clips along the side. The center of these large surface area tanks are unsupported. The sag in the center of the tank when full tells me, no do not press my luck.
Something else not talked about is the change in loaded tongue weight with full tanks. This is a camper specific issue. If you have a several hundred pound TW increase or decrease this needs to be understood and compensated for. This reason alone may prevent some folks from being able to tow stable with a full fresh tank. And it may be worse with full black and gray at highways speeds. Around the campground to the dump station not an issue. Get out on the open road at speeds above 45mph and things change.
