djcjc
Jun 29, 2017Explorer
Hauling water
Whenever we go to the races in Joliet I travel with water tanks full only a 20 minute drive and buy water only if we run out. Headed to the race in Sparta KY about 6 hr drive no water hookup at CG bu...
JBarca wrote:Huntindog wrote:
John.
My tanks are like ktmrfs as far as the mounting goes.
I did have a sagging problem with the FW tank. I fixed it with a welded metal support system. I don't believe in using wood in any way for tank supports.
A trip that we take at least once a year across the reservation has horrendous frost heaves on the road. This road will defineatly show any weak areas. So far, so good.
Thanks, good to know.
I agree on the wood concerns for tank supports when it is in a structural pulling capacity which mine has with the screws holding the black & gray. Since Sunline made my fresh tank cage so beefy, it is an assumption they never intended the black and gray to haul long distances full at highway speeds. I will address this if we change camping needs requiring us to not have ready access to a dump.
And yes, backcountry roads show up all the weak areas of a camper, hangers, frame attachments, axles, tanks you name it.
Thanks
John
