Putting aside the issue of transporting firewood, I think you're asking about the weight on the rear of the camper. Not knowing what kind of camper you have, how long it is, and without doing the math to figure out how much tongue weight you'd loose, its really kind of hard to say what the impact would be.
My new Outback came with the 1 inch? receiver hitch on the back, already installed. Warning labels give a weight limit, which isn't all that much, but is adequate to carry a basket-cage that slides into the receiver. Although I had to get the step-up receiver, from the 1 inch? to the 2 an 1/4?? standard receiver, the carrying cage works pretty well. However!
All that weight hanging on a single post, with the width on both sides, causes the cage to wiggle back and forth, a lot! If you add something like this, for whatever you carry, it will probably have a lot of wiggle back and forth also.
In order to stop the wiggle, I attached 2 2x4 boards bolted to each end of the cage that catches on the top of the square bumper. So, the actual hitch carries the weight, and the 2x4's stop the rocking back and forth. No weight on the bumper, it's just used for balance. Too bad, I don't have a photo.
So, in your consideration of a single receiver hitch, take into account the rocking back and forth, because of the slack in the hitch and the shaft that goes into the receiver. I think that will be a bigger problem than the weight you're loosing on your tongue, especially if your trailer has any length at all.
Just my 2 cents. Good luck .... and please do rethink transporting firewood. In Indiana you can transport and even bring it into the state parks now, but the bark has to be removed and subject to inspection. So the rules are lifting in some places.
Good luck!
EDIT:
We went to the Indianapolis, Indiana RV show in 2010. I snapped these photos of a North Country camper. I really liked the way the installed the bicycle carrier. This carrier could carry anything. Notice, it uses the concept of two receivers instead of a single one.
I STRONGLY suggest you do something similar, if you're going to carry anything on the end of your camper. This will eliminate all the wiggle!
