LabLover99141's avatar
Aug 27, 2024
Have TTs gotten any better?
My husband and I full timed for 5 years in a 34' Cougar and loved it.  When we finally planted, we tried a TT with sway bars for all of about 2-3 trips and hated it. We're now looking at a Arctic Fox 29-5K fifth wheel for more elbow room.  Before we take the plunge, has anything improved in travel trailer towing?
  • As a new person to the RV space I'm amazed at how crappy this industry is.  Sales people don't actually know real information about things.  They know it's got a king size bed or a refrigerator but for most of them it ends there.  It's difficult to find real world detailed information.  Youtubers tell you either everything is great or how their fridge stopped working.   I've spent 100 hours researching and learning because real information about TT is hard to find.
    • valhalla360's avatar
      valhalla360
      Navigator
      And unnecessary if you set up the trailer weights correctly.
      It might mask the problems with a boarderline setup but a poor setup, it won't fix.
  • I’m with the rest on this issue. The correct set up is of upmost importance.
  • It has always been "Buyer Beware".
    My first Rockwood tent-trailer, purchased in 1978, came with a a standard starting battery, not a deep-cycle battery.
    The battery lasted less than a season. I would be careful with the newer RVs. Manufactures are cutting corners to keep the cost down.
      valhalla360
      Navigator
      I believe he is referring to how they tow and not much has changed.
      As far as batteries, for the typical guy who goes from modern campsite to modern campsite, there is really no need to upgrade to deep cycle batteries. If they die in a year, either you are boondocking and leaving them depleted or your battery charger has failed...either item can kill much more expensive deep cycle batteries.
  • I agree with the two previous posts. Nothing has really changed; you need tot have the proper tools, setup correctly. Lacking that causes issues with towing wether it’s a TT or 5er.
  • Better? Not really. I agree with Valhalla, it's all about the right equipment. TTs and FW's will always tow fine provided they are loaded correctly and in specs. Likewise you have to have the right tool for job - ie - truck. A FW or TT overloaded, tire psi not set right, unbalanced weight and/or a truck that is not up to specs to tow the weight will result in an experience that is not fun or plain dangerous. Right equipment, set up right will tow fine. I don't feel like that's anything new.
  • Travel trailers tow just fine. We had 60mph cross winds on a prior trailer...we got off the road as soon as possible but no sway. Most problems can be traced to incorrect setup. The biggest issue is getting enough tongue weight.  At 12 to 15%, it won't sway at all.  This presumes you aren't skimping on the truck. An overloaded truck can be uncomfortable.  A properly set up wdh helps but won't overcome a light tongue weight or overloaded truck.
    Fifth wheels tend to be much more forgiving because they start around  20-25% pin weight.  The big catch is you need a truck capable of handling the pin weight. This usually pushes you to a 3/4 tongue for smaller 5ers and quickly jumps up to 1 ton dually as you get larger.
    A 10k trailer will need about 1200-1500 lb with travel trailer or 2000-2500 lb with 5er. Obviously some info on truck and trailer can dial in a suggestion better.
