Lynnmor
May 13, 2016Explorer II
cruz-in wrote:Lynnmor wrote:GaryWT wrote:
My truck has build in sway that will apply brakes if needed but I like the sway that is part of my hitch.
The device in question can select right or left trailer brakes as needed, your truck cannot.
I don't believe that is the case with this device. As it is plugged into the 7 pin connector it only has access to the brake wire which activates all trailer brakes.
Now the dexter electronic anti sway control (that is hardwired into the right and left brake wire), operates as you describe with activating left or right trailer brakes as required.
I'm sorry, you are correct. I first thought that it was just another copy of the Tuson system.
44,056 PostsLatest Activity: Jan 12, 2020
