FishOnOne wrote:
transamz9 wrote:
FishOnOne wrote:
Cummins12V98 wrote:
goducks10 wrote:
transamz9 wrote:
FishOnOne wrote:
dfb wrote:
Had an 04 Dually 6speed.. sold in 1/2 hour for 25k. Bought a loaded 15 Laramie megacab with AISIN, auto level rear suspension.. stickered at 69670. Paid 58000... Real Happy with the Rams. 865 lb ft and 385 hp.. interior is the best. Super comfortable and smooth quit ride..Pulls our Montana like a freight train...Most in our area drive Cummins... it gets no better...
Give us a full report after 100k miles and then we'll talk. By then I should have 200k miles.
I have a 14 with 120,000 miles on it that gets beat on and idles most of the day. It has averaged 25 MPh for its life . It's been in the body shop twice getting the sides repaired from being run out of the road twice ( so the driver claims). Oil changes, wipers and brakes is all the maintenance has been
Don't confuse Fish with personal true stories. :B
I kinda like his "brothers cousins wives neighbors" stories. :)
Did we conveniently forget these?
I don't need to take a picture of the stack of recalls sitting on my desk for the Ford trucks we own. All manufactures have them.
BTW, my 2005 has never been in a shop of any kind to be worked on.
You're singing to the choir.... Ram has had the highest quantity of recalls last year and the largest financial penalty slapped on them in automotive history including buybacks.
Sure... All manufactures have safety recalls but ram takes it to the extreme level with one being a poor quality weld that holds the pan hard bar to the frame and the fix is to bolt on some silly bracket (Band-Aid)that bolts around the questionable weld.
That questionable weld was probably actually a handful of trucks but to only way to be safe is to recall enough to make sure they get them all checked out.
The latest one I have on our Ford F150'so is the possibility of the master cylinder to dump the brake fluid into the break booster. Yeah, having your steering break loose is bad but so is running out of brake fluid. ;)
