travelnutz
Jul 26, 2015Explorer II
ksss,
If you have an LLY engine, these are the engine specs.
The GM LLY Diesel engine is 305 HP and 605 @ 1600 RPM torque - nearly a true flat torque curve spec all the way from 1600 RPM up to 3000 Rpm. 32 valve design and a 17.5/1 compression ratio. Began production as a 2004.5 mid-year first build for sale in GM 2500HD and 3500HD pickups and continued until the LBZ replaced it beginning with the 2006 model year.
Check your engine specifications for your LLY.
