brulaz
May 02, 2013Explorer
Roadrash450 wrote:
and the NorthTrail's are now being manufactured with Azdel laminate panels.
Well, the 2013 North Trail brochure says Azdel in the "sidewalls". The roof and floor will still have various layers of plywood or chipboard.
And what about the front and ends? You would think they'd use the same stuff as the sides, but some manufacturers construct the front and rear ends completely differently from the sides, with different materials.
For example, many Keystones, like the Passport and Bullet, use fibreglass (filon?) laminated to lauan/framing/insulation on the sides. But the front and back walls are non-bonded, "hung" walls with no lauan, rather a thin, flexible filon/paperboard product is layed over the frame/insulation and held in place at the edges. And the front insulation is fibregalss bats, not block foam (dunno about the rear). Apparently the paperboard backing allows them to match the front curvature better. Lauan doesn't bend as well. Dunno why they do the same in the rear.
I wonder whether a fibreglass laminate with azdel backing is flexible enough for Lance and the other azdel users to use it on the curved front of their trailers? And whether is is laminated or just hung? They certainly should be able to use a true azdel laminate on the flat rears.
