BubbaChris wrote:
I'm the 2nd owner of a North Trail. There's a small amount of water damage in the front wardrobe. Almost directly above that area the seam between the front cap and roof was damaged by a tree branch.
Absolutely no other signs of water intrusion. When the camping season is close to over for the year I plan on having a leak test done (positive air pressure in the TT). At that point I'll know for sure how leak-tight my unit is.
The only real problem I've had so far was a leak in the shower diverter, which I atribute to the prior owner not winterizing properly.
Save your money on a leak test, there are so many holes in places that you can't see that you won't build any pressure.
The RV industry practices the "if the mitre don't fit, fill it full of muck and s@$&" process of manufacture.
Just look in some of the nooks and crannies and trim panels, you'll see what I mean.
