dbbls wrote:
Clonefan wrote:
2008Wildcat wrote:
You probably have a digital thermostat, and the fan was set to auto instead of on or off.
The new digital thermo's are set to run the fan in the a/c to help circulate the warm air. Should have just been the a/c fan running, not the compressor...
This. The fan in the auto position was most likely the reason.
My fan must be in the "AUTO" to work properly. If it is on "high or low" it will run when the furnace is on.
Mine has a fan OFF position. I put the there when the furnace is on.
