pianotuna
Dec 29, 2015Nomad III
There are heat pads that can be attached to the water tank. There are similar units for the pipes and waste tank valves. That may be a better direction to follow.
It is also possible to run hot water into the tank by adding a hose from the water heater to the fresh water tank. Control the flow with an electric valve using a thermostat on the side of the water tank.
