rbpru
Dec 30, 2015Explorer II
Sometimes the temp sensor is located near the plug. If the plug is in a warm area the sensor will not detect the cold temp outside.
I would also be suspicious of the hydrant freezeing.
An easy check would be to coil your heated hose in a bucket outside and when it has chilled, plug it in outside. It should be a bit warm in a few minutes.
Some of the newer heat tapes use temperature sensing wire and do not have a separate temp sensor.
