There are a number of safety features on furnaces that "GENERALLY" make them more of a pain in the ass th make work that not working correctly and causing a fire. That being said, if there are problems with CO2 most of the heaters haze zero safety in bad gas. older campers also didn't come with a co2 monitoring system.... install one.
I too use a Mr heater, but I do not sleep with it on. I'd be really happy with a wave6.. still not sure I'd ever feel comfortable sleeping with it on, without proper venting.. whats the point of opening a window and letting the snow blow in to run the heater.
To each their own and CHANCES are you'll never have a problem, how does the lottery phrase it... you don't play you can't win;
"Each year, more than 400 Americans die from unintentional CO poisoning, more than 20,000 visit the emergency room and more than 4,000 are hospitalized due to CO poisoning. Fatality is highest among Americans 65 and older.Each year, more than 400 Americans die from unintentional CO poisoning, more than 20,000 visit the emergency room and more than 4,000 are hospitalized due to CO poisoning. Fatality is highest among Americans 65 and older."
http://www.cdc.gov/co/faqs.htm
Have fun, go shopping for a warmer sleeping bag or even better both a new bag AND a 12Volt heated mattress pad, ABSOLUTELY the best thing ever on ski trips/ cold WX camping.
Paiger loves it anytime of the year, and we now have one at home 120V version for our bed, it comes with 2 sides 10 position of heat and when used with a timer....
I only wish it had a cooling setting for summer use:)
Repo
