time2roll
Oct 04, 2017Nomad
westend wrote:Ok on my 26' foot trailer OEM three floor vents down the middle. The duct is boxed aluminum about 2" x 10" and was installed poorly and rather restricted. Bathroom was very warm and the main area with two openings was very weak.
I don't use the typical RV furnace but I'm curious about one thing--you folks that are increasing duct size or flow rates, do you notice less airflow in ducts that were not modified? Has the temp coming from the unaltered registers and ducts as hot as before modifying any heat runs?
I'm just curious about this, no ill will intended.
Added the two more ducts just short and easy to the main area. Sure there is less through the original ducts but still tons more heat exactly where it is needed. Can now leave the bathroom door closed.
