westend
Nov 25, 2016Explorer
swimmer_spe wrote:westend wrote:
I'd suggest you remove the battery that is in the trailer and take it somewhere for testing. Without disconnecting it and having a failed converter, the chances of it having any usable life are low.
Have you tested the converter with a meter to see if the converter has failed or if the fuses are intact? Often, the circuit breaker between battery and converter is tripped. This circuit breaker is sometimes hidden below the frame or in a junction box.
The converter was inspected by a trailer dealer here. I will be replacing the battery in the spring anyways.
How do you plan to run the furnace with an inoperable converter and a questionable battery?
44,056 PostsLatest Activity: May 04, 2014
