rlyons's avatar
rlyons
Heavier Tires on Travel Trailer
I have been riding on the original China made Westlake tires on my 2015 Flagstaff 26FKWS travel trailer. The original tires were load range C on 14 inch rims. I have since ordered new Goodyear Endurance tires in the same tire size but with a heavier load range D rating. The old tires listed a maximum pressure rating of 50 lbs, the new ones maximum are 80 lbs. I'm wondering what pressure I should run the new tires at because they already have a greater load range carrying capacity but am concerned if I run them at 80 lbs will it be too stiff a ride on the trailer. I have the torsion type axels on this trailer.Should I go with 60 lbs or run at the full 80 psi?
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
