tewitt1949 wrote:
I had to replace my tires on out TT and it came with 12 ply tires.  I wanted something heaver.  I ended up going to a 14 ply tire that is used on trailers that are used to haul bull dozers etc. (construction equipment)  They were only $20 more per tire than the 12 ply.
Seems you might be confused since AFAIK no TT has ever been supplied with 12-ply (that's F load range 95psi inflation) tires.   14-ply is a G load range with 110psi inflation and that would be silly to be putting that heavy of a tire on a TT with a GVWR in the 10 to 12K range.
There might be a couple of HUGE 5ers like the 40'+ Mobile Suites tri-axle that have this load range tires, but those are a very, very small number percentage wise of RV trailers.
Larry
