Mikell
Oct 31, 2021Explorer
Correction. The connection points are part of the inside surface of the exterior frame (not the interior frame). The more I look at it, I’m considering running a 1” wide piece of aluminum bar stock (as thin as practical) down either the inside or outside of the exterior frame plastic channel the piece broke from, and riveting it to that channel. If I place the aluminum stock on the outer surface of that channel, I may be able to reuse the broken piece’s connection point. I could also run a piece of aluminum stock down the inside of the track as well, sandwiching the plastic channel wall between the aluminum.
44,071 PostsLatest Activity: Aug 30, 2026
