ticki2
Nov 02, 2021Explorer
Mikell wrote:
Correction. The connection points are part of the inside surface of the exterior frame (not the interior frame). The more I look at it, I’m considering running a 1” wide piece of aluminum bar stock (as thin as practical) down either the inside or outside of the exterior frame plastic channel the piece broke from, and riveting it to that channel. If I place the aluminum stock on the outer surface of that channel, I may be able to reuse the broken piece’s connection point. I could also run a piece of aluminum stock down the inside of the track as well, sandwiching the plastic channel wall between the aluminum.
This is the approach I would use . I would use an adhesive but not rely on it alone having the forces of the lock lip on it . Sandwiched with aluminum and riveted will probably hold up , you can only try , I have use similar repair on other projects with success . Good luck .
44,071 PostsLatest Activity: Aug 30, 2026
