Mikell
Apr 30, 2022Explorer
Well, it’s been a few months since I’ve had the time to attempt to implement my fix. I finally finished it today. I sandwiched the broken section between two slats of aluminum, attached with JB Weld and rivets. It doesn’t look pretty, but it’s not noticeable unless you are looking for it. I was also going to try the YouTube fix I referenced earlier in the thread with the locking bar to provide additional protection; however, my Heki must be a little different than his because the bar would not go straight across the bottom of the skylight bottom (apparently it bows downward slightly. So, I came up with my own version which are just two locking clips. I think this should solve the problem. If you want to try it, you just have to notch the clips to fit. I did place a flat washer in two places on each side at the ends near the clips the same thickness of the aluminum angle used for the clips so I could slip the clip between the HEKI latch and the skylight.
44,071 PostsLatest Activity: Aug 30, 2026
