JW2
Feb 05, 2015Explorer
Fastbrit: Sitting inside the cab over area and looking up, I measured the plastic area immediately above where the sliding screen is. The measurements are: side to side = 32 ¼ inches, front to back = 20 ¾ inches.
In the single photo you posted in your first post, the beige colored portion is the part that is installed on the exterior of the camper roof. There are also three black attached hinge pieces in this photo. Each of these three black hinge pieces has two tabs on their ends where a pin is installed through these tabs and the mating corresponding tabs on the beige colored portion. It is some of these corresponding tabs that are part of the beige colored portion that are broken on my unit, and possibly the black hinge piece(s) also. So, if you would send any parts you do not need, to specifically include the parts with the items shown in this first photo of your first post, I would be ever so grateful to you!
