hohenwald48
May 14, 2016Explorer
You must have been posting the pic at the same time I was typing my response.
With the switches set as in the picture, the fan should not run. Most likely the installer mis-wired something. It is possible that the thermostat is bad (not likely) or the control board in the A/C has failed. The first thing I'd do is run down the wiring and make sure it's connected properly on both the A/C end and on the thermostat end.
You can download all the wiring diagrams you need from the internet.
44,068 PostsLatest Activity: Apr 17, 2021
