budwich
May 15, 2016Explorer
I think they had a "couple of issues" ("onion skin" so to speak). The AC problem had some issue since it was blowing fuses (likely a motor issue / compressor problem) but the "fan on" issue was also there all along which might still be a wiring error (either at the thermostat or AC box), since it is likely that the "installer" might have only did a "unplug/plug" and things "worked" thereafter (ie. no fuse blowing). Anyways, I don't see an easy way out without doing some good wiring investigation which will take time and understanding which will mean $$ if you don't do most of it yourself. :-(
Too bad the country is so big ... :-)
44,068 PostsLatest Activity: Apr 17, 2021
