upnorth15
May 15, 2016Explorer
budwich wrote:
I think they had a "couple of issues" ("onion skin" so to speak). The AC problem had some issue since it was blowing fuses (likely a motor issue / compressor problem) but the "fan on" issue was also there all along which might still be a wiring error (either at the thermostat or AC box), since it is likely that the "installer" might have only did a "unplug/plug" and things "worked" thereafter (ie. no fuse blowing). Anyways, I don't see an easy way out without doing some good wiring investigation which will take time and understanding which will mean $$ if you don't do most of it yourself. :-(
Too bad the country is so big ... :-)
That's for sure!! Might be cheaper to fly you out here to fix it. The wishy washy poor customer service seems to be the norm anymore. You've been great and educated me so I've got some knowledge of what might be going on when I talk to them again. Thanks again Kathy
44,068 PostsLatest Activity: Apr 17, 2021
