budwich
May 15, 2016Explorer
I was looking thru the net at some old similar issues on other setups and one indicated that they replaced the control board (in the ac unit - under the label that you pictured earlier... its not cheap though). There problem was similar that the ac compressor was running and could only stop it by pulling the breaker / fuse.
here is the "example"
http://www.irv2.com/forums/f54/dometic-duo-therm-low-profile-ac-111902.html
44,068 PostsLatest Activity: Apr 17, 2021
