enblethen
Jan 19, 2023Nomad
Make sure your converter is charging the batteries.
Check wire size between the jacks and the batteries.
Jacks could be drawing more amps. Have they been services and lubricated?
Have you checked what voltage the batteries are providing?
Adding battery may not help.
Verify that the batteries are wired correctly. Positive from one battery and negative from other battery. I am guessing you have two 12-volt batteries wired in parallel!
