bigfootford
Jan 20, 2023Nomad III
like enblethe said..... Check and make sure your converter is charging your batteries.
My HJ's and 2 group 24 FWC batteries would raise and lower my camper many times before the batteries would not work the HJ's.
My camper weights 4300lbs...
I now only have one AGM battery 100 ah and it will raise and lower a bunch of times before going below the 11 or so volts under load that will shut off the HJ controller.
It takes well over a day for your batteries to fully charge when they are low on charge.
If left low on charge more than a week your NEW batteries will loose capacity. And each time you let them sit for all length of time they will be dead or useless in less than XX months.
Jim.
Jim.
